gerryExplorerJun 03, 2018electrical systemApparently you should leave your 12 volt battery system on even when connected to a land line for an extended time. Question is, will weak batteries have a negative effect on the electrical system? ...Show More
stickdogExplorerJun 03, 2018If you're conected to AC your converter should supply your DC needs as well as charge your batteries.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
Related ContentElectricElectrical assistanceDIY electrical systemElectrical outlet issuesElectrical management system
