Apparently you should leave your 12 volt battery system on even when connected to a land line for an extended time. Question is, will weak batteries have a negative effect on the electrical system? ...
Depends what is meant by "weak". A "low" battery will simply get charged up, no problem. A battery with a bad cell could overwork the converter and cause a problem.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
