Apparently you should leave your 12 volt battery system on even when connected to a land line for an extended time. Question is, will weak batteries have a negative effect on the electrical system? ...
Some older converters require a 12 volt battery to "smooth" the voltage. Give how poorly many converters work (even new ones), leaving connected is my default choice.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
