dougrainer
Feb 11, 2018Nomad
Most Google searches will bring up WRONG 7 way trailer wiring and colors. This is the correct code. Doug
Left Turn is RED
Right Turn is BROWN
Running is GREEN
Ground is WHITE
Brakes are BLUE
12 volt HOT is BLACK
YELLOW goes to the center pin and can be whatever you want it to be(reverse/brake buddy/anything) The Yellow is DEAD on RV's and Trucks from the Factory. It has been years since I have found a Yellow connected to the Reverse lights on a OEM vehicle.
Left Turn is RED
Right Turn is BROWN
Running is GREEN
Ground is WHITE
Brakes are BLUE
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
