dougrainer
Feb 11, 2018Nomad
1. Does the Arista HAVE a 7 way that appears Factory installed? I assume you are NOT the original owner and who knows what previous owners have done to the Arista wiring system.
2. Attempting to tap OFF the 3 wires you mentioned may not be a good idea, unless you have determined they ARE--RED (LT)---Green (RT)---Brown(running lights), which would be OEM code.
3. Is the Honda already wired for Lights, or are you planning on tapping into the existing Honda Wiring? Not a Good idea unless you go all the way to the Rear Honda lights and install Diodes to prevent feedback and possible damage to the Honda OEM wire system. Doug
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
