Rascally_Road_W's avatar
Jul 22, 2013
Electrical Wire Fire
I was awakened by a strong electrical burning odor around 2:am. The inside of the RV Travel Trailer was filled with smoke. The smoke detectors seem to be working, however, they didn't go off that night.
I first got everyone out of the RV (wife & cat) and then unplugged the unit from the outside 30 amp plug-in. I then disconnected the battery and moved our mattress to another location and went back to sleep.
The next day I investigated the source of the smoke and found this:
It was later determined (according to an RV repair shop) that the reason for the burned wiring was because either one or two of the wires on the neutral bus may have come loose creating additional heat which in turn caused this problem.
The shop claims that it is a good idea to periodically check to make sure that the screws on both buses (Neutral & Battery) connecting the wires. Apparently the bus will expand and retract some from the heat causing the screws to loosen over time and that the screws should be checked at least every 6 months.
Now I'm no electrician so I am just following procedure. If this is true as far as checking this every so often, then I would like to post this information to warn others.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
