bob
Jun 28, 2014Explorer
electrican sent 240v to my rv.
Was having a 30 amp circuit installed  to run my air on a 1993 Itasca rv.  Electrician screwed up an tried to run on 240.  Looks like he smoked the converter, what else can I expect?
calamus wrote:
The amp rating of the wire should never be less than that of the circuit breaker that is used.
Yes there are cases where you could use a 3 wire 240 volt but I have not seen any residential wiring done other than a well (and that is rare) with 240v 3 wire they have not done it for years now.I see it every day. I have two of the 3 wire 240 outlets in my residential outbuilding, less than 10 years old. They are part of the original electrical system, permitted and inspected of course. One is for an air compressor, another for a heater.
calamus wrote:ScottG wrote:calamus wrote:
There should of been a 4th wire if it was 240v.
There's a 30A 240V outlet that only has three conductors that is common for use with welders and compressors. That's probably how he wired it.
even a 30A 240v will have 4 wires hot hot netural ground. If you have seen one I would like to see a link the only time I have seen where you use the 3 wire system for 240 volt is in a two wire submersible well pump it only has a hot hot ground coming off the pump so you would combine the netural and ground or just run 3 wires. Like I said this is a major screw up. If it was done at a home then and 3 wires were used I just can see someone with any know how could do this. You would know that as you hooked up in the panel when you didnt have a netural and or a ground wire??? This guy was an idiot.and should lose his/her license but Im guessing he doesnt have one.
