bob
Jun 28, 2014Explorer
electrican sent 240v to my rv.
Was having a 30 amp circuit installed  to run my air on a 1993 Itasca rv.  Electrician screwed up an tried to run on 240.  Looks like he smoked the converter, what else can I expect?
calamus wrote:
This is for a CAMPER, Yes there are cases where you could use a 3 wire 240 volt but I have not seen any residential wiring done other than a well (and that is rare) with 240v 3 wire they have not done it for years now.
wa8yxm wrote:
Things are improving.. Used to see a new thread like this just about every week, Now I can go months without seeing one.
I always advise folks who think to ask to have a 50 amp outlet put in, not a 30,, Two reasons,
The minor reason: You might wish to upgrade some day, Very easy to upgrade from 50 to 50 or from 50 with a 30 amp breaker to 50.
The REAL reason: See original post.
I have heard, over the years (about 10) I've been here many rumors of parks where the 50 amp outlet was wired wrong, SAFE but wrong with the same leg feeding both sides of the outlet (Well it is not the safest but thankfully the RV makers use wire a bit heavier than absolutly needed so the odds of a disaster go down should that happen)
I have heard of exactly ONE case where a 50 amp outlet had a polarity reversal and sent 240 volts into the RV (And that was about a week ago). (And in an RV park).. But threads like this. Very common.
Damage list: Anything that easts 120 volts possibly including but not limited to:
Radios
Televisions
Sat receivers
DVR/DVD/BlueRAY/VCR/CD players
Some TV antennas (Doubtful but there are a couple)
Converter
Control board on Fridge
Energy Management systems if any.
Microwave
And if you have anything plugged in like a coffee pot
Heat elements in fridge and water heater.
Some air conditioners, epically if running
Would be on my list, basically ANYTHING that uses 120vac power.
sue.t wrote:
The inlaws' fridge worked on propane after a similar thing, but would not work on electric, either 120 or 12V. Needed a new fridge.
Also needed to replace a fair bit of wiring in the RV.
calamus wrote:ScottG wrote:calamus wrote:
There should of been a 4th wire if it was 240v.
There's a 30A 240V outlet that only has three conductors that is common for use with welders and compressors. That's probably how he wired it.
even a 30A 240v will have 4 wires hot hot netural ground NOT NECESSATLY !!! Again someone who does not know what he's talking about !!!!!!!!!!!!!
. If you have seen one I would like to see a link the only time I have seen where you use the 3 wire system for 240 volt is in a two wire submersible well pump it only has a hot hot ground coming off the pump so you would combine the netural and ground or just run 3 wires.
WElders, Air Conditioners, Table Saws, to many thing to list that just use two hot wires and a ground wire. NO neutral required.
Like I said this is a major screw up. If it was done at a home then and 3 wires were used I just can see someone with any know how could do this. You would know that as you hooked up in the panel when you didnt have a netural and or a ground wire??? This guy was an idiot.and should lose his/her license but Im guessing he doesnt have
one.
