Grey_Mountain's avatar
Mar 22, 2018
Electric/Gas Heat Pumps on Class A Discovery
While on a quick trip to Nebraska, we were using our heat pumps on "Electric" to heat the coach. At one point, the they quit blowing heat and started blowing cool air. They also automatically switched to "Gas." Unfortunately, we had just run out of propane. Is there any connection between the two events? Don't understand how there could be, but when it comes to things like that, I'm a pretty good wordworker...
GM
  • On my unit, the heat pump and furnace are controlled by the same thermostat. Yours is most likely similar. When the outside temp gets to the point that it no longer can put out heat, it will automatically switch to furnace mode and is supposed to switch back when the outside temp warms up. If the heat pumps continued to blow air after it switched to furnace, I’d have the system checked.
  • DrewE's avatar
    DrewE
    Explorer III
    There's certainly a connection between switching to gas and blowing cold air when you're out of propane. There's no direct connection between running out of propane and the heat system switching to gas mode, which is to say running out of propane doesn't cause it to switch.
    RV heat pumps typically don't operate at outside temperatures below something like 30 - 40 degrees, and automatically switch to using the furnace for heat at that point (or possibly electric resistance heat strips, if you have them on your units). If you don't have propane, the furnace clearly isn't going to produce heat.
    Needless to say, the system operating on gas mode will use propane and so eventually cause it to run out if not refilled in due time.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
