Bill_Satellite
Jul 23, 2020Explorer II
Here's the thing (if it has not already been clearly stated). You have a 30 amp coach and that's a fact that cannot be changed by plugging into a 50 amp plug. The good news is that plugging into a 50 amp plug with the proper 50/30 amp dogleg adapter is not a bad thing. It just does not change the fact that you have a 30 amp coach and you still cannot use more than a total of 30 amps total. 50 amp coaches are able to use 100 amps with 50 amps spread between 2 separate 50 amp legs.
