wnjj
Apr 23, 2018Explorer II
Bill.Satellite wrote:cekkk wrote:
I had a 30 amp outlet installed at my garage for our 30 amp RV. My friend and electrician did a good job and used 110.
Now have a neighbor being told MHs' outlets should be 220v. States he's done it beofore for people. That's contrary to anything I've ever heard, but I could well be wrong.
So, 110 or 220 for neighbors outlet?
And for the sharp-eyed, I made a similar post on a different forum, not RV.Net.
Tell your neighbor that he is an idiot! All RV's (OK, a few exceptions) use 120V. A 30 amp RV MUST be wired for 120V. A 50 amp coach MUST be wired for 120V. However, the 50 amp RV has 2 legs of 120V service and between the 2 legs there is a reading of 240V if you connect a meter but nothing in the coach is wired for 240V. Hooking up your 30 amp RV to 240V = BOOM!
Uhh, the neighbor said the MH outlet (assume they meant receptacle) should be 220. IF it’s a 50A service which many MH’s have, it is indeed a 220 “outlet” (240/120 but most people just call it 220). Whether the MH uses 240 or not isn’t the point.
Calling it 2 legs of 120 is more dangerous since it doesn’t describe them as being on opposite ends of the split phase. Wiring a “dual 120” would result in an overloaded neutral if both hots were on the same phase.
Nothing idiotic involved, just ambiguity about 30A or 50A RV.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
