Harvard's avatar
Harvard
Electricity and electric and magnetic fields (EMFs)
Is the Electrical problem "Induced" or what?
START QUOTE:
EMFs are invisible forces that surround electrical equipment, power cords, and wires that carry electricity, including outdoor power lines.
•Electric Fields: These are formed whenever a wire is plugged into an outlet, even when the appliance is not turned on. The higher the voltage, the stronger the electric field.
•Magnetic Fields: These are formed when electric current is flowing within a device or wire. The greater the current, the stronger the magnetic field.
EMFs can occur separately or together. For example, when you plug the power cord for a lamp into a wall socket, it creates an electric field along the cord. When you turn the lamp on, the flow of current through the cord creates a magnetic field. Meanwhile, the electric field is still present.
END QUOTE:
If it is induced then it is from a Magnetic Field.
If it is capacitance then it is from a Electric Field.
Your body is 1/2 of a capacitor and unless you are off the grid, it is always exposed to an Electric Field.
For example....
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
