Son_of_Norway
May 08, 2013Explorer
I take it that you are still just trying to run it out of a gas can? That's actually the way I have to run mine right now until I get around to replacing the fuel line to the gas tank. My fuel line was disintegrating and tiny pieces of rubber had plugged up the carb. You may have the same problem. You say that you have good spark, try spraying a little starting fluid into the air intake and see if it runs. If it does then take off the carb. and spray the passages out with compressed air, then spray them with carb cleaner. That should get it going. Put on a fuel filter, and make sure that your fuel pump hasn't been contaminated with junk that could be plugging up the carb. If you find little rubber bits, you may also need to replace your fuel line. Post to this thread again when you've tried these things and let us know what happens. Then we can figure out what to do next. Good luck with your repairs.
Miles
Miles
