DownTheAvenue
Jul 06, 2017Explorer
I bet your current problem is not related to your A/C or the generator. I bet you have a bad ground. Check all the cables very good, and make sure there is no corrosion. A loose ground could also be the issue. Follow the negative cables until they reach a ground and make sure there is a good connection.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
