McKenziek
Jul 09, 2017Explorer
My apologies for not posting. After I got things working we got on the road and were out of cell coverage area all weekend. Thanks to all for chiming in. Here is what I think happened. As per what others said I had two issues, the 120 issue i'm guessing is what Mr Wizard mentioned and I definitely learned something here. Disconnect shore power prior to starting generator. I think this fixed itself after waiting a bit for the transfer switch to reset.
The 12 volt issue was due to a battery kill switch which the previous owner installed and I guess might be faulty. The fact that the lights came back on and then dimmed and then went out made me think of the switch. The switch is a dash mounted type, up is off, down is on. Once I switched off and then back on the dash alarm went out and the lights came right back on.
Thanks again for the replies.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
