Matt_Colie
Jan 20, 2019Explorer II
Bill.Satellite wrote:
That's what I was going to say as well. That's what usually happens when 1 bulb is out to alert the driver to the problem.
This can also happens if you tried to put an LED bulb where a standard bulb used to be.
free radical wrote:
I was just considering replacing regular bulbs with LEDs
How do you prevent this flashing then?
Free,
You have to look at your current flasher, it will be two or three pin. Then go get an electronic constant rate flasher with the same pin count. But, now it will not change when a bulb goes out....
Some require you to add a ground wire.
Matt
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
