SidecarFlip
Jan 20, 2019Explorer III
free radical wrote:Bill.Satellite wrote:
That's what I was going to say as well. That's what usually happens when 1 bulb is out to alert the driver to the problem.
This can also happens if you tried to put an LED bulb where a standard bulb used to be.
I was just considering replacing regular bulbs with LEDs
How do you prevent this flashing then?
By the load resistors from the LED light supplier. Super Bright sells them, where I got mine. An electronic flasher unit will also work with LED lights with no resistors. Your choice.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
