kcny
Jul 23, 2014Explorer
othertonka wrote:haddy1 wrote:
Most "aux start switches" don't actually switch battery banks, they tie the banks together. If your chassis batteries are really low, or bad, the switch may have to be held for some time because the bad batteries draw most of the initial load.
I agree with this post. push and hold the button a little while and let the two batteries equalize. It is kind of like using jumper cables, hook up and let the jumper vehicle run a little bit before trying to start the dead vehicle.
While holding the button down, you should notice the volt meter on the dash rise as well right? I know on mine you do, but when I used the aux start the battery was just low (not dead), so not sure if that makes a difference.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
