Bobbo
Aug 20, 2020Explorer III
SpeakEasy wrote:
I don't see a clear consensus.
I have great tires: new GY Endurance.
I don't have a power-hungry rig; about a quarter of the time we dry camp.
So - based on input given, no clear consensus other than "get both."
-Speak
You will never see a clear consensus here. On anything. You have to take the differing opinions, with their rationale, and decide which one fits your needs better.
Whether the rig is power hungry has absolutely no bearing on the question. The question is whether the power supplied to the rig is clean, reliable power. That is totally independent of what you have.
I do believe that both are very useful. I have both. I got the EMS immediately. I got the TPMS when I discovered an inside dually tire completely flat. Not low, flat. It was fine when I started driving that morning, but at the end of a 500 mile leg, it was flat.
However, I also understand the funds conundrum. My personal opinion is EMS first. Like someone else has pointed out, every time you stop for gas you can kick each tire. If they go THUNK, THUNK, THUNK, THUD, then you know the THUD tire is different. My father was a professional, over the road, bus driver. He kept a ball peen hammer in his carry-on. He would hit each tire with it before getting in the bus. It didn't tell him the psi number of the tire pressure, but if all the tires had the same THUNK sound, the tires were all inflated about the same, and would be fine.
