wjmblm's avatar
wjmblm
Engine Compartment light on
I have a 1999 Pace Arrow motorhome.
I have noticed that the light in the engine compartment is on.
I cannot figured how to turn it off. None of the panel switches seem to do it.
Hope someone can explain how to turn the light off.
Thanks,
William Moore
  • Yes it was a rocker switch marked ‘Utilities light’. When the switch is in the up position the light is off, when in down the light is on.
    Seems like it should be the reverses to me. But thanks to everyone for the answer and help.
    William moore
  • kimbo1 wrote:
    there is a rocker switch at the drivers location that turns lights on in engine and wet bay compartments
    I agree with this. Look at the very low row of switches on the left side of the dash. Should be a switch for the engine compartment light and a switch for the wet bay compartment and maybe a switch for the tog lights.
  • there is a rocker switch at the drivers location that turns lights on in engine and wet bay compartments
  • Shut the hood and the light should go off. There's probably a mercury type switch that is activating when the hood is up and that's normal. If I'm wrong, unscrew the bulb until you find the problem.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 04, 2025
