time2roll
Jan 10, 2016Nomad
If you just remove 50/50 and fill with 50/50 you are fine.
Likewise if you start with a dry system, adding 50/50 works fine.
Gets more complicated when you also rinse with distilled water. Then you need some 100% to mix with the water that remains. As said add half the capacity with 100% and top off with distilled.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
