MEXICOWANDERER
Dec 17, 2018Explorer
Pulse Charging
Strontium Plate Alloy Additive
Battery Eye
Par for the course
Meticulously create a problem where the never was one -- then BS your way through a miracle answer. Much like losing your brakes in the old days...pedal hits the floorboard and you'd swear it made the car go even faster...
Wotta hoot. I have a nine ton bus and an alternator that consumes almost 22 horsepower when angry. The effect of 22 horsepower is not felt at all. Take an EIGHTY AMPERE alternator and connect it to an 8 horsepower Honda 4-stroke gasoline engine. Start engine, advance throttle to 3400 RPM, Enable voltage regulator, motor loads a little but maintains speed at full eighty amps output.
This is supposed to be magic? It is mouse milk. Cruel deception. An air intake VORNADO that swirls air into a nuclear powered vortex as it enters the carburetor. Step on the starter after adding VX6 battery additive and the starter will rip its way through the hood and disappear leaving a comet trail of surplus ions in it's wake.
But this is the age of Con-Artistry. Politically Correct Unicorn Food. Declare it GREEN and then watch the mob see green, swallow brown, and beg for more
Yeah Delco had it right in the 1980's. Manufacture a 15 volt auto voltage regulator to do along with it's proprietary calcium/calcium Delcotron battery then expect consumers to pay 37% more for a DELCO battery. Oops! Blow the snot out of a replacement battery with 15 volts? "Well we told you the Decotron was special".
Clancy made have had it right, with that disaffected Japanese airliner pilot novel.
Battery Eye
Par for the course
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
