landyacht318's avatar
landyacht318
"Enhanced" flooded starting batteries for stop start auto
Many modern Autos intentionally keep the battery discharged to the point that when the driver lets off the gas, or hits the brakes, the battery can then accept higher amps when the voltage regulator commands 14.5+ volts. This acts as a poor regenerative braking MPG enhancer and a battery that basically is Never fully charged
This results in the continuous partial state of charge cycling of starter batteries, and short lifespans and not long after, whining customers demanding new batteries under warranty which then eats into profits.
Looks like the marketing departments saw something to peck at and perhaps there is some engineering following suit to keep the beancounters from screaming too loud.
Looks like the carbon additive to the plate paste in some modern deep cycle batteries is working its way into the Automotive starting battery world.
For those who do not want to click the below links:
Increased dynamic charge current acceptance over standard wet-flooded batteries (+170%), due to improved design including special Carbon additives and high charge acceptance envelope type separators
Increased cyclic durability over standard wet-flooded batteries (+100%)
Sealed tip/tilt double lid with integrated flame arrestor
Exide invented the first EFB battery in 2008, helping European car manufacturers to reduce fuel consumption and emissions for small to mid-sized cars. Our technology is now considered the most advanced in the industry. The latest-generation EFB battery offers significantly improved charge acceptance and cycle life, a result of key breakthroughs in lead alloys and unique carbon additives that came from our R&D efforts. Exide’s Start-Stop EFB batteries enable Start-Stop, regenerative braking and other powerful fuel-saving features.
https://www.yuasa.co.uk/info/technical/agm-efb-explained/#efb
http://www2.exide.com/gb/en/product-solutions/transportation/product/exide-start-stop-efb.aspx
If this leads to batteries that are more resistant to hardened capacity destroying sulfation from chronic undercharging, the bane of all lead acid batteries, well mo bettah for us intetionally deep cycling the lead acid beasts and have systems designed for charging this medium.
Argue away.......
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
