Mariner14's avatar
Mariner14
Enough Solar for conservative boondocking?
Hey Guys, I looked for the "Dumb Questions" thread, but didn't see it, so I'll post my question here.
I want to be able to boondock for 3-4 nights with my family of five on our 28 foot TT. I don't plan to need a lot electricity. I was thinking we would only need the furnace fan, a few lights at night, and water pump. The fridge, water heater and furnace all run on propane, so just their control panels would need some current as I understand it. I was thinking of adding a second battery, but for the same price I could get a small 50-100 watt solar panel to charge the one battery during the day. Wouldn't that be enough to keep us going based on our conservative power usage? What am I not considering?
Also, with just one small solar panel, I could just hook it directly to the battery to charge it, right? I wouldn't need a charge controller or whatever, right?
Thanks
  • Thanks for that. I am not going to do LED lights as I don't think we'll use lights enough to make a difference. I don't like the idea of worrying during the day if I'm overcharging the battery, while I'm out on a hike or something. So overcharging is a thing? Is there a charge controller or something I should put between the panel and the battery?
  • If you have LED lighting, heater fan runs less than 25% of the time through the night and none during the day, you should make it. Under the conditions you describe, a solar panel right to the battery during daytime hours should work. Keep a meter on the battery just to be sure you don't go over 14 volts just in case you didn't use much battery the first night or so.
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 22, 2025
