dougrainer
May 17, 2022Nomad
Bobbo wrote:dougrainer wrote:Bobbo wrote:
EPDM
TPO
Fiberglass
Aluminum
I would avoid the first two. My first RV, a Winnebago had a fiberglass roof. The same stuff that was on the sidewalls. My current Airstream has aluminum. When shopping I immediately ruled out anything with EPDM or TPO.
Please explain the basis for your comment. I have over 43 years as a RV tech. I have seen ALL roof materials. While I also would prefer Fiberglass, I would NOT like Metal roofs. Metal roofs will be damaged by normal size Hail that would dent a car. Fiberglass, rarely. It takes a LOT to punch holes thru fiberglass. It takes a LOT for Hail to damage a TPO/EPDM roof. For cost, I would like a EPDM/TPO roof. Your Airstream, the COST basis alone makes a Metal roof standard. Doug
The basis for my comment? Personal preference. While I know that a good hail storm will dent my aluminum roof, I would be REALLY surprised if it punctured it. Dents, I can live with. You state that "{i}t takes a LOT to punch holes thru fiberglass." I posit that it takes more to punch a hole through aluminum.
The Aluminum can get "cuts/cracks" instead of holes. While you state a Hailstorm will dent your roof. Well, A/S's do NOT just get dented roofs. Depending on which way the storm is blowing you get hail damage on various sides also. Regular RV's (very few metal sides left) just get roof top hail damage unless Fiberglass. Doug (we also service/sell A/S)
