ScandentTrek's avatar
ScandentTrek
Explorer II
Aug 23, 2023
Electrical Issue: Converter, Battery, Something Else?
Hey folks! Long time reader, first post!
So we've lived full-time in our 1997 Fleetwood Mallard 30ft for almost 4 years. Until recently we were plugged in at a full-time RV park and had no electrical issues.
We recently moved to a new location (MIL's house) with no 30amp connection. We're plugged into the house (15amp house plug with appropriate dogbone converter plug and surge protector) and while we plan to be here for a while (4 months or more), we aren't sure if adding a 30amp plug is in the future.
Since we got here we've been having a new and odd electrical issue.
Our on-demand water heater (DC) started turning on and off randomly, causing it to beep at unexpected times. Sometimes it actually flickers so quickly it doesn't beep, but we can see the display flashing on and off. We also noticed that our range fan (on the same circuit) has similar power fluctuations, causing the speed to rise and drop rhythmically. None of our other DC appliances have this issue. None of our AC appliances are having an issue. We've even been able to run our AC unit through these heat waves.
We discovered that if we turn off our converter, we don't have this problem. Without the converter, everything runs smoothly, although of course this slowly drains the battery.
Now, we tried changing the outlet we are plugged into, not using a GFCI outlet in case that's the issue, but it didn't make a difference.
Our battery is still charging nicely, and the converter seems to be in working order. On battery power only, everything works perfectly. Turn the converter on and eventually, some hours later (but not immediately), the flickering starts again. Turn the converter off, and immediately the flickering stops and everything is good.
I don't want to do too much guessing, but I'm wondering if there is an issue with the converter when it goes into maintenance mode after the battery is fully charged again. Or this is a problem with using 15amp shore power instead of 30amp? Possibly the battery?
Has anyone had a similar issue? How would we go about troubleshooting this?
We're just praying it's not a problem with the wiring behind the walls. Thanks in advance!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
