dieseltruckdriv
May 18, 2022Explorer II
dougrainer wrote:THAT is why I like reading your posts. As simple as it is I wouldn't have thought of doing it that way but it would definitely work better than what I would have done.
snipped
PS, Use the link and use that glue to do your repair. What I do for your type is to cut out the square area and remove the rubber. Cut a slightly larger piece of rubber and glue in place and then use Eternabond around the perimeter.
https://dicorproducts.com/product/water-based-bonding-adhesive/
I would have cut a slit at the bubbled part, laid it down flat and put Eternabond on the cut part to seal it. I still wouldn't have the repair glued down doing that, even though it would be sealed.
I am also a lousy carpenter. ;)
