jodeb720's avatar
jodeb720
EPDM roof Material or Something Else?
I remember reading this a while ago - there are two types of roof's installed on RV's. EPDM and something else.
I know 2Oldman is the king of all searches - but I'm not that good.
I remember the way to differentiate was the coloring on teh back.
Today I pulled one of my vents off and found the color on the a "blackish" color. Which roof type do I have -
And as long as you're reading this.. What adhesive do I use to reattach a replacement piece to the sub-straight base?
Thanks
Josh
  • Bobbo wrote:
    EPDM
    TPO
    Fiberglass
    Aluminum
    I would avoid the first two. My first RV, a Winnebago had a fiberglass roof. The same stuff that was on the sidewalls. My current Airstream has aluminum. When shopping I immediately ruled out anything with EPDM or TPO.
    Please explain the basis for your comment. I have over 43 years as a RV tech. I have seen ALL roof materials. While I also would prefer Fiberglass, I would NOT like Metal roofs. Metal roofs will be damaged by normal size Hail that would dent a car. Fiberglass, rarely. It takes a LOT to punch holes thru fiberglass. It takes a LOT for Hail to damage a TPO/EPDM roof. For cost, I would like a EPDM/TPO roof. Your Airstream, the COST basis alone makes a Metal roof standard. Doug
  • Bobbo wrote:
    EPDM
    TPO
    Fiberglass
    Aluminum
    While I would prefer fiberglass or aluminum, for the cost to upgrade to a rig that has them, you could replace the rubber roof options several times over.
  • Bobbo's avatar
    Bobbo
    Explorer III
    EPDM
    TPO
    Fiberglass
    Aluminum
