path1's avatar
path1
Equalizing charge ...help
According to Battery university... "Not all chargers feature equalizing charge. If not available, the service should be performed with a dedicated device".
Question... So what "dedicated device" performs a equalizing charge?
I bought a Schumacher model #sc11 "automatic battery charger". Manual says zero about "equalizing" charge.
My old battery charger still works but does not shut off when battery is fully charged. That was reason for buying new battery charger, old charger kept charging until all water boiled out.
Can I use my old charger and just disconnect when battery level gets around 15 or so?
(My elec level is about 2 out of 10, so please use elec words/terms a lay man can understand)
  • 2oldman wrote:
    Sure, but what will you do with the new charger?
    To late to take back. And new charger only charges up to 12.05 volts then shuts off. Kind of disappointed in it.
  • What is the voltage on the new charger ? If it finishes at anything above14.4, its all you need,....depending on who ya believe.
  • Your old charger will probably work unless it is just a 2 amp trickle charger. It needs some oomph to get a deep cycle battery up to equalizing levels.
    The old one is a "manual" charger, which you must turn off instead of an "automatic" charger, which shuts itself off when the battery reaches a certain voltage, say 14.4v.
    First--make sure the fluid level is just below the split rings or else it will rise to overflow when you get the battery charged up and overcharging. It will rise but should not overflow. if too high to start, suck some out with your hydrometer.
    Use the new charger to get the battery "full" (according to the charger--which is really about 97% full with most of those kind) Then put the manual charger on the job and let the voltage rise to 16ish volts. You should spot check the SG with your hydrometer. Once the SG stops rising you are done. The charger will likely "stall out" in the 16s or at least slow down in voltage rise a lot, so you can let it keep going for a time there, but stop if it tries to keep climbing.
    If the electrolyte overflows right away or the voltage rises to 16 right away, then the battery might be sulfated too much. It should take a little time for the voltage to rise from 14.4 to 16.
