Michael_in_MN
Aug 31, 2013Explorer
MEXICOWANDERER wrote:
- If any two cells in one battery have a .15, that's point one five difference between the highest and lowest cell, it's due to be equalized
Do you mean .15 difference (I.E. 1.275 - .15 = 1.125) or do you mean .015 (I.E. 1.275 - .015 = 1.260)?
FWIW - Trojan says '...if the specific gravity value of any individual cell varies 30 points or more...' which I presume would be .030, correct? East Penn says '...or a wide-ranging specific gravity between batteries (0.030) after being fully charged...'
I'm finding confusion on decimal points on various sources - for example East Penn also says '... If the variation between the highest and lowest cell reading in any one battery is .50 (50 points gravity) or more, it is a good indication that it has a failing cell.' But 1.275 - .50 = .775, which clearly is impossible, so their published doc must be wrong. I'm sure they mean .050, not .50.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
