j-d
Jan 18, 2015Explorer II
I think we're on different sentences on the same page. Of the three primary angles, Caster/Camber/Toe, Toe is the only one that can be set independently. At least without modifying the geometry that's built into the chassis. Changing Caster to get more with be limited by acceptable Camber.
I visited John at the iconic Henderson's Line Up in Oregon. He worked in the shop 25 years, doing loads of alignments. Said "Caster is the Change in Camber as you Steer."
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
