Harvard
Jan 21, 2015Explorer
Here is a 2007 Honda Civic EX, Honda Spec for Caster is +7.0 on each wheel.
It is crucial that the camera sit on a stand which is parallel to the ground surface. The ground surface must be flat BUT not necessarily level.
Steering wheel is full right.
Drivers side camber measures NEGATIVE 1.853
Passengers side camber measures POSITIVE 4.618
Drivers side turn measures 27 Degrees
Passengers side turn measures 28 Degrees
Estimated Caster K:
K = (180 / 3.14) * ((4.618 - (-1.853) / (27 - (-28) )
K = 57.32 * ( +6.471 / +55 ) = +6.7 Degrees
as opposed to specified + 7.0 degrees.
Note: Measured resolution of camber degrees based on pixel counts in the high resolution original JPG files. (and yes, pixels have been confirmed to be square :B)
Estimated Caster K:
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
