TurnThePage's avatar
TurnThePage
Eternabond Failure
I have to eat a little crow. A while back someone posted that Eternabond could trap water behind it, thus causing rot or some other issue. I cockily responded with, How could water get behind it? Well I found probably half a cup of water trapped behind Eternabond tape wrapped around my fridge vent. As I kept searching, I found that a good amount of the tape had dried out and literally rotted away. In the attached photo, you can see where I used left over tape to secure solar cable to the roof. Look how it cracked open. If you look close, you can see tiny cracks all over it. Yeah, it's a mess too. :B
  • I have had my eternabond on the front cap seal start doing the same thing. Fortunately I caught it a few weeks ago but also had a bit of water damage. Mine has been up there about 8 or 9 years. Mine is in the same place over the dicor caulking. I think that may be the issue too. Other places look fine.
  • Hard to tell depth in the close-up picture. Was the EB stretched to get down in that valley that was holding water?
  • Well one more reason to do a yearley inspection and re seal of your roof.
    Bill
  • It's probably been up thete 12 years. Why would roof prep or, lack of, cause the tape to dry out and crack?
  • How long was the Eternabond on the roof?
    Did you apply it, (or can you blame it on someone else?) :)
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
