N-Trouble's avatar
N-Trouble
Eternabond prep and install advice
I purchased a 50' roll of 6" wide to lay along the roof edge on each side of my 5er. You can see i have had a couple of incidents with trees that put a few quarter size tears in the rubber roof.
I hear prep and install is everything when it comes to laying this stuff down. My plan is to wash with soap/water then use some mineral spirits along the area to remove anything else.
As far as laying the Eternabond down you can see there is an arch in the roof line about 5' back from the front cap. Should I use two separate strips that meet/overlap at the arch or is the stuff playable/bendable enough to start at the front cap and run one continuous 25' strip down each side?
I've also heard its a good idea to take something like a rolling pin to it after installing to make sure good contact which I plan on doing.
Any other advice?
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
