BFL13 wrote:
I am confused by the Eternabond info. Is the 4" wide, white tape the material that does not need UV protection or does it--- but you can put the UV protection on later if you don't have any of that handy?
Thanks
I like that it does not stick to your hands and make you go through one of those old Red Skelton skits with sticky tape :)
So is the tape a WB-Seal or not?
"(EternaBond® Tintable UV Protector is only required when using WB-Seal on areas exposed to sunlight. All other EternaBond® leak repair products are UV protected and require no other protection. UV Protector can be tinted to match most surface colors. This step can be performed at a future time.)"
This seems to say it is WB-4 "Webseal"
https://www.amazon.ca/EternaBond-WB-4-50-Web-Seal/dp/B005GOM6PMBTW that $98 looks good! Around here, the RV shops want $ 3.75 a foot from an open roll, and a 50ft roll like that is over $150.
