Bert_the_Welder
Oct 08, 2020Explorer II
OK... this got misunderstood a bit it seems.....
No Alum. tape was involved.
E-Tape wouldn't stick out past the outside surface of the window frame/trim so not visible, so wouldn't look like a hack job. I used 2" as an example as it's the narrowest I've seen it come in. Not to say it doesn't come narrower, just that's all I've seen. So it your walls are an 1.5" thick, you'd be left with a 1/2" wrapped to the outside wall surface. Not that yours or all walls are that thick, but it's just as an example.....
