Bert_the_Welder
Oct 08, 2020Explorer II
LarryJM wrote:gbopp wrote:
Would the (minimal) thickness of the Eternabond interfere with the window seating properly on the butyl tape?
I'm thinking it could leave a small gap between the window and the side of the RV.
Maybe it would be better to just use the tape they use on houses?
Instead of Eternabond if I was redoing a window I would wrap the opening like the OP suggested with 2"/3" wide aluminum tape. It's extremely thin and would make the opening basically waterproof. You would just have to be careful installing the window to avoid tearing the tape.
Larry
That's why I wouldn't use Alum. tape. Way to fragile. Plus, when a screw goes into it, it doesn't have that "self healing" property that EB has. And Shoving a window into a frame, you are guarantied to tear it. PLUS the Alum. tape won't handle expansion/contraction well.
