groundhogy's avatar
groundhogy
Eu2000i muffler cleaning ideas?
Its $135 for a new one.
Mine is completely blocked. If you blow on it, nothing goes through.
Any ideas?
What is the internal structure of these things?
Is it just a cavity or is there like a zig-zag path?
  • For soaking, im thinking non-flammable is better, but I guess I can let it dry a long time.
    Techron idea is interesting. I know i can get a bunch of that..
    • Buy a bottle of TECHRON
    • Remove muffler
    • Plug one end with a rag
    • Fill with Mouse Milk
    • let it soak overnight
    • use a can to catch what seeps through the rag
    • Drain
    • Toss in a slug into the gasoline reservoir
    • Start get aerator and put it under load
    • Is this effective?
    • You will see results
    • Point the exhaust away from anything you value
    • Run the generator for at least an hour.
  • Lynnmor wrote:
    It's on page 55 in my owners manual.
    Great... send me your manual so that I can read it :)
  • Soak the muffler in carburetor cleaner, you can find carburetor cleaner in a gallon dip/soak can with basket. Most auto parts stores have it. When done soaking, you rinse off with water.
  • This is an easy job. Follow these instructions HERE.
    Note that in the manual it says to clean the spark arrester every 100 hours or 6 months.
    I bet no one does it, I know I don't. I do mine every so often when I think about it and that is usually way over 2-300 hours.
  • Tvov's avatar
    Tvov
    Explorer II
    Most small engine mufflers are not designed to be taken apart, they are usually just welded together - or even just press fit together.
    Mufflers interiors can be a variety of styles, from "maze like" to baffles to just an expansion chamber.
    Do you think it was / is a mouse nest? That is not uncommon in a stored generator.
    Have you tried a simple piece of wire with the end turned into a small hook? Clothes hangers work great. Many times you can get most of the material out, the rest will "burn off" - make sure you run the generator in a safe area for a long time in case anything catches on fire (temporarily, we hope!).
    If it is carbon build up, that is difficult to get out if it is not near the inlet or outlet.
    If you are lucky, the carbon buildup may just be at or near the outlet, especially if there is a "spark arrestor" screen - simply scraping that clean may work.
    If a part / baffle inside the muffler has been damaged, usually rusted, and is blocking the exhaust, the muffler needs to be replaced.
    Many times in the process of "cleaning out" a muffler, it will be damaged to the point of needing replacement anyways. If it isn't working now, you may as well try to clean it, even if in the process it gets damaged more.
    Good luck - lol, maybe $135 is worth it after all.
  • There are carbon solvents made for cleaning guns, automotive use, cookware, etc.
    If you don’t want to buy one specific for your job, I would remove the muffler from the engine and try some oven cleaner on it.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 26, 2025
