msiminoff
May 22, 2013Explorer II
RoyB wrote:
... I almost think the twist lock receptacle 26.6A on the generator is not active unless you connect two of these 2KW generator in parallel.
Both outlets are wired in parallel (with each other and also with the parallel cable banana jacks). The only difference is that the 20A outlet is protected by the circuit breaker, the L5-30P is not. Power is available at all outlets any time one or more of the generators is running.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
