RoyB
May 23, 2013Explorer III
msiminoff - thanks for the info... I was just looking at the info on the front panel that says 20AMPS for the 20A recetpacle and 26.6AMPS for the twist lock receptacle. There is definitely not 26.6AMPS there unless you are paralleled to another 2KW Generator... Actually without being paralleled there wont be 20AMPS available at the 20Amp receptacle either. Each generator by itself can only produce 13.3AMPS
again tks for the info - Never had touched one of the companion units.
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
