SAR_Tracker
Jan 04, 2014Explorer
Either a breaker in the trailer has tripped, or (more likely) there is another GFI outlet that has tripped. Check in the storage bays - they sometimes are in there.
OR - the GFI outlet has gone bad and needs to be replaced. Can you remove it and test for incoming power to the outlet?
Did you press the RESET button on the GFI outlet AFTER you pressed the TEST button? If not, it's still tripped.....
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
