acemyers
Jan 04, 2014Explorer
SAR Tracker wrote:
Either a breaker in the trailer has tripped, or (more likely) there is another GFI outlet that has tripped. Check in the storage bays - they sometimes are in there.
OR - the GFI outlet has gone bad and needs to be replaced. Can you remove it and test for incoming power to the outlet?
Did you press the RESET button on the GFI outlet AFTER you pressed the TEST button? If not, it's still tripped.....
I searched outside and in the bay and they don't have a GFI. I can remove it, but I don't have anything to test it with. I'm probably going to make a trip to the store and get something to test it with and possibly a new outlet. Would Walmart have everything I need? Only thing open right now. Also, what do I buy to test it with? Yes, I hit the reset button after and before the test button and still nothing. come to think of it I don't think the GF I outlet is bad. Because when I hit the reset button and held it in my indicator light on my portable heater went off. When I released the reset button the red indicator light on my heater came back on. so if the buttons made my heater light go off and back on that would mean that the outlet is good correct?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
