opnspaces
Jan 04, 2014Navigator III
I would guess that the GFCI is not connected to the 2nd AC. maybe there is a second breaker panel somewhere.
To clarify because I either read your post wrong or there was an error. The light on your heater should go out when you press the test button. The light should come back on when you press the reset button and the reset button should stay in when you release your finger.
On your breakers make sure that you push them firmly in the off position before flipping them back on. A tripped breaker will not always reset unless you push firmly off first.
We had another poster the other day with something kind of similar. they found two extra breakers in an outside storage by I think an auto transfer switch. Anyway I would check again for any other GFCI outlets or breakers.
You can buy a cheap GFCI tester at Walmart but I'm not sure if it will tell you anything if you are getting partial power. From the behavior of the heater light it sounds like you have partial or low voltage. Here's a link to a tester that has a button you can press to test the GFCI operation.
Link
You will probably wind up also needing a multimeter before this is all done.
Digital multimeter
If all else fails call an electrician or mobile RV tech.
Link
Digital multimeter
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
