BFL13
Jun 18, 2013Explorer II
Your 6v batts will get you more AH (220 say) than the two 12s (160?) so that is not the problem
You have a draw somewhere. That 13.4v does not means your batteries are charged. That means they are just getting charged on the way from 12.x in the morning to 14.x in the afternoon. Whether they ever get fully charged (12.7 resting) depends on how much daylight is left after they get to 14.x and can do the absorption stage before dropping to float voltage of 13.8 whatever the set point is for that.
You need to watch the Trimetric amps and see if amps are negative net when they should be positive. Say your solar is adding 10amps, you have a 5amp draw, you will see 5 amps charging showing. If you have more draw than incoming, down it goes.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
