BFL13
Dec 15, 2015Explorer II
"Now I understand that when a battery is up in absorption voltage range, the amps required to hold Absv keep tapering. If the amps do not taper then voltage will just keep rising"
This concept still bothers me. I don't believe the amps keep the voltage up.
The charger voltage is kept up by itself. The battery voltage is based on the SG of the electrolyte. The difference between the two voltages makes for amps across the R.
If the charger voltage is maintained amps will taper as battery voltage rises.
I don't think that if you somehow dropped the amps (by having a lower amp current-limit charger?) but kept charger voltage steady, that battery voltage would suddenly drop too. I think it would just rise more slowly from then on.
I think LY has the tail wagging the dog, but I could be missing something in all this.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
