dougrainer
Mar 13, 2022Nomad
Your RV is 22 years old. Odds are the fuel tank was not very full for those years it was not used. The main thing that ruins Fuel pumps/Sending units is MOISTURE that rusts out the components in the fuel tank. What you need to do, is have the RV towed to a shop capable of dropping the fuel tank after draining and then cleaning out the interior of the tank to remove the rust and rust flakes that WILL be inside the tank. You need a new Fuel Pump/gauge sending unit. They will also need to flush out the fuel feed and return lines from the tank to the engine. Doug
