Grit_dog
Mar 13, 2022Trailblazer
So you’ve diagnosed that the pump is not running, presumably since you’ve replaced the fuse and relay. (Was the fuse blown? If not, why replaced?)
If the tank is 3/4 full as you say, Then the pump didn’t freeze up due to oxidation. It is and was submerged.
Before dropping tank, any rodent damage? Chewed wires a possibility?
Any chance of siphoning or pumping fuel out?
