Gary45
Mar 17, 2022Explorer
211Racing wrote:Gary45 wrote:
My E350 based motorhome has a lift pump in the tank and a fuel pump mounted on the frame just behind the front wheel. If yours the same check electrical connection.
That's very interesting. I replaced the fuel filter just behind/below the driver's seat. Didn't see a pump. What year is yours? I assume you mean the left front wheel? I'm not seeing that set-up for a 2002.
Mine is a 1986 , the gas supply is set up like fuel injection even though it has a carburetor, there is a pressure relief valve near the carburetor so constant flow through return to tank.
The pump is mounted on the frame below drivers seat.
I read somewhere it was done that way because in a motorhome the gas tank is farther back, also with the constant flow through the lines less chance of vapor lock.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
