211Racing's avatar
211Racing
Expert Fuel Pump Opinions Needed!
Just got a 2002 Tioga 24D. Base is a Ford e350 Super Duty van. Will turn over strong, but starts for only an instant. With the help of Starting Fluid, will run for several instants. Zero pressure at the fuel rail. Tightened the gas cap. Replaced the Fuel Pump Relay. Replaced the Fuel Pump Fuse. Replaced the Fuel Pump Filter. Checked and cleaned the Inertia Switch (button is down). Thumped the bottom of the tank several dozen times. Absolutely zero effect. I am reluctantly moving ahead to draining the 40+ gallons of fuel and dropping the fuel tank to replace the Fuel Pump. Can you think of anything that I have missed before I commit to this job? Thank you for your help. (And ... I checked to see if I could access the Fuel Pump through the floor in the back of the RV. Lovely thought, but not possible).
  • We bought an 8-year old coach in 2012 that had sat for I think 2 years. We were able to drive it home and then had our mechanic go through it because we wanted to take it to Alaska. He changed all the belts, hoses, fluids and filters. Gave it back to us and said. . . "I didn't change the fuel filter/pump because I would have had to drop the gas tank and didn't think you'd want me to do that." Okay. Shakedown cruise went great. Second time out, lost the fuel pump. Fortunately were close to a truck repair place and they ordered the pump and filter and dropped the drivetrain and fixed her all up. The gas that had been in it, was not treated when she was made to sit, so that was the culprit. We had the tank drained and cleaned out while they had it out. Once done, put in all new fuel and all was good. She went to Alaska and back and now, 9 years later I am still using her.
    Dale
  • Have you checked for power and ground at the tank connector? I would test the circuit first before pulling the tank.
  • jdc1's avatar
    jdc1
    Explorer II
    If you know someone with a motorcycle jack, you will not have to drain the tank.
  • Crawl under near the tank. Have someone cycle the key from OFF to ON (not start). You should be able to hear the fuel pump run for about 10 seconds.
    Sometime in the 1990s (?), most manufacturers (Ford for sure) started adding a fuel pump control module. These are usually near the tank. They are known to fail.
