Gdlow
Sep 08, 2016Explorer
K Charles wrote:
The cruise cuts off because it thinks you stepped on the brake. Which way do you turn the signal to make the cruise quit?
Either way...
When setting still (here in a park), I turn on the turn signal...it flashes correctly, then I step on brake and it stops...I then pulled the umbicale (sp) cord out from the MH and the turn signal keeps working...sounds like it is the cord...I had electrical spray and it didn't help...so must as fellow above says...is probably a short..
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 30, 2026
